Option for "Audio channel": reverse
In the app menu under "Audio channel" there is:
- stereo
- mono
- left channel
- right channel
Just to make the list complete it would be nice to have something like "reverse" that switches left and right channels.
Excellent suggestion.
at the level of the speakers then....
(it was just to make a "word"... but fundamentally the reverse is more of a "comfort" function that can be easily achieved otherwise... this is not the case with a mono or a balance etc... or better peb ,or fonction subwoofer for the amp etc)
you can also ask for fonction " reverse the phase"....( classic on somewhat ambitious digital sources, see certain hdg preamps etc.)
but yes...it can be done at the speaker level...
:cool::p
