WiiMer SJ
My Wiim Pro is sourcing Edifier active speakers that are not equipped with 12V Trigger functionality. So I went looking for a solution, found and purchased this:
Iot Relay - Enclosed High-Power Power Relay for Arduino, Raspberry Pi, PIC or WiFi, Relay Shield https://a.co/d/0FSd1p3
I also purchased these:
Harmony IR Adapters, Ancable 2-Pack 2.5mm Mono Plug to 3.5mm Mono Jack Connector for Logitech Harmony Hub and IR Blaster, IR Emitter Extenders, IR Repeaters, IR Receivers https://a.co/d/4c81sGu
Ancable 2-Pack 3.5mm 1/8" Monaural Mini Mono Plug to Bare Wire 6-Feet - 12V DC Trigger ON/Off Cable https://a.co/d/3vADchk
All of the above should arrive tomorrow. I will update this thread when and if it all comes together.
IoT Relay
Create the Internet of Things with safe, reliable power control. Universal control voltage 3-60VDC or 12-120VAC connects to Arduino, Raspberry Pi, PIC or other micro. Or connect directly to a 12V to 48VDC or even 120VAC circuits. High voltage wiring and safety hazards are eliminated. A single...
dlidirect.com
