Question about outputs... two different sources
stregnil
Nov 8, 2023
Hi, I don´t have a Wiim yet, but about to get the Wiim Pro.
Question... I will connect the Wiim Pro Coax to Coax to my Gustard X16 headphone DAC, and I will connect the Wiim Pro SPDIF - SPDIF to my active speakers.
Is it easy to change between the two outputs?
My active speakers will be main, and when I sit down and listen to my headphone I will change to Coax. (I will not use the outputs simultaneous)
Do you see any disadvantage with this setup, or anything else?
You can easily switch between WiiM outputs with the WiiM app. However, the music will stop when you switch the outputs. In the case of Spotify, you can press the play button to resume playback immediately. In the case of Amazon music, you need to select the playlist again. The behavior may vary depending on the source being played.
You can also switch the output on the device's settings screen.
