Spotify Connect not seeing wiim pro plus. But can connect via AirPlay?
daktau
Nov 18, 2023
So, this was working fine last weekend. Unplugged everything from the wall then powered back up after a week.
Opened Spotify from the wiim app on my iPhone where Spotify connect can see my radio but now, not the wiim.
If I click on airplay from the Spotify connect device screen the wiim is there and connects.
Unplugged the wiim and powered it back up - no change.
Checked wiim and phone are on the same wifi network.
Anyone know of any changes or whay may br causing this?
Reboot your router, and ensure that “show local devices only” is turned off under settings/devices in the Spotify app. Also try turning the DNS option to 8.8.8.8 in your device’s network settings in the WiiM Home app, and turn off ipv6. If possible set your router’s DNS to 8.8.8.8/8.8.4.4 as well.
Aha! Very good advice, thank you very much!
It was turning off “show local devices only” that did it.
Spotify->Profile->Settings->Devices
It was the first thing I tried and instant success! Extra happy Saturday, thanks again.
