Squeezlite issues with analogue out
CrystalGipsy
Sep 13, 2023
243
@WiiM Support
I can’t get the Squeezelite input to work correctly. As the device is not Roon Ready yet I was planning to use the Squeezelite support to add it to Roon. I don’t like Airplay or Chromecast.
I can add it to Roon fine but it plays silence unless I toggle volume one step. If I stop playback and start again it’s the same behaviour no sound until I toggle the volume. If it’s set to fixed output it won’t work at all.
If I use LMS to UPnP plugin which bridges UPnP input on the Wiim to mimic a squeezebox and this is added to Roon it works just fine. So something is off with how it’s sending out a signal via analogue out.
Hi CrystalGipsy,
Please kindly send us feedback on the WiiM Home App so we can troubleshoot this immediately. Thank you for your assistance in advance!
