Subwoofer doesn't turn off
dannep018
May 29, 2023
9
Now i have been playing with my Wiim Amp for a few days and it performs better than my expectations.
But i have one problem.
My subwoofer doesn't turn off after i stop using the amp.
So now i need to manually switch it off on the subwoofer before going to bed.
Have anyone else problem with the same thing?
Any solution for my problem or does it need to be addressed with a firmware update?
My Eltax subwoofer works fine with the Amp - switching in and out of standby automatically.
I just have my subwoofer on a smart plug, called sub. Just use the WiiM remote to say sub off or on. I also have a schedule set to turn off sub after midnight if i forget.
Do you know how much energy your smart plug uses?
