Switch between Bluetooth and Wi-Fi
gamechanger
May 30, 2023
5
I've connected TV to Wiim Pro via Bluetooth.
If while playing TV sound I start to stream audio via Spotify Connect, Wiim Pro disconnects from TV's Bluetooth.
I think it's better not to disconnect from TV's Bluetooth but send Pause signal to TV and switch to Spotify Connect (and still not disconnect Bluetooth connection).
If after that, TV starts to play music again, Wiim Pro should switch to Bluetooth input.
So switching between any Wi-Fi and Bluetooth inputs should work like switching between different Wi-Fi inputs, for example switching between Airplay and Spotify Connect.
