Upper limit of mini devices in wifi mesh?
kechambe
Mar 5, 2024
Is there an upper limit on the number of devices in a WiFi mesh?
This particular use case is around synch auto across boats in a tie-up. Probably does matter but output will be line or optical to the boats sound system.
Not aware of a limit on the number of devices in a Linkplay group - guess you might need to directly raise a ticket to WiiM for such info. What sort of numbers are you talking about?
I would love to learn 250 devices are no problem.
Knowing 50 works or “should work” is enough.
I worked at Cisco once upon a time ago and can figure out how to scale the network side of things. Just want to know if there are any know limits or product enforced limits before I buy 50 of these things for $5000. 🙂
That's a lot!
Compared to its siblings, the Mini only has a quarter of the Ram and half the processing power. I understand Linkplay groups use a primary/secondary model where the primary device in a group takes on the role of receiving the stream and then distributes that to the secondary. Consequently, it might mean a Pro or Plus would have to take on that primary role.
I think your use case is probably fairly unique so you would really need WiiM engineers to say definitively what could be achieved. Contact them by email or by raising a ticket thru the settings/feedback section in the WiiM app. Good luck.
the music will be sent from a DJ mixer. I can buy a couple Pros if that enables more scale.
Maybe I should open a support case.
You could go the old school route and use the FM band. I own one of these and it works well, I used it in the pre-streaming days connected to a SirusXM receiver and got more than the advertised 150 feet from it. Be mindful that the FCC might not approve.
Whole House FM Transmitter 3.0 https://a.co/d/4PobFza
