Pytaniedodcf
- Joined
- Dec 2, 2023
- Messages
- 30
Hi Pro Plus Staff;
It’s great that the source can be switched using the Pro Plus remote.
However, it would be helpful if the selected input (Ethernet, Bluetooth, Line, or Optical) could be identifiable on the device.
Currently, Optical In has a green LED (similar to Line In). Perhaps Optical could have a red LED momentarily, when switching to it with the remote?
Would you take this into consideration for future firmware updates?
Regards;
Pytaniedodcf
Regards;
Pytaniedodcf
