FerengiROA
Looking for clarity on this. My system is as follows:
1. Wiim Pro
2. Schitt Modi 3+ DAC
3. Onkyo TX-NR6050 AVR
I haven't bought a headphone amp, yet. Still researching.
My plan is to add a headphone amp between my Wiim Pro and AVR. I would use Optical out from the Wiim to my AVR optical input. For non-headphone listening, I am using Coax out from the Wiim to the DACs' Coax input. Then, using my Zone 2 analog output to the analog in on a headphone amp. Obviously, I would bypass the Schiit DAC and rely on the DAC in my AVR.
I could then use Zone 2 for the headphones while still being able to adjust the volume using the AVRs remote..This is necessary as I am listening about 8' away from where the headphone amp needs to be located.
Does this plan seem logical? My headphones are Beyerdynamic DT770 Pro/250 ohm and I feel they would benefit from an external amp.
Thanks for any advice you may have.
1. Wiim Pro
