Firmware 4.8.528755 build date 20230908 PEQ
Mr Ee
Nov 11, 2022
1,994
Sydney, Oz
One of my Pros updated to this fw version.
Simply cannot get PEQ to work.
Very buggy.
No matter which number in the 3 cols I press, it always says "Change the Q factor:"
The numbers shown on the page do not update when I enter new values, but it does seem to be remembering them as the changed values are shown in the popup when I re-press them.
There is no slider, just a number input screen.
The cursor always starts on the left, but the 'keyboard' shown doesn't have arrows to move the cursor, so you always have to press in the number to be able to delete/enter something. Particularly silly as the only delete key is to delete the character to the left of the cursor.
Where is the graph of the curve?
Although it does seem to be remembering each number I enter for each cell (row / column), if I exit the eq screen then go back into it, the last change i made to any value per row, such as setting gain to 10, is then applied to the Q value for that row.
Try deleting the app and re-installing it. Which o/s and app version are you on?
The graph for PEQ appears above the table of parameters on both my iPad and Android phone app,
Very buggy.
It sounds like the bugs in the beta haven't been fixed. Or worse.
Can you drag 4 round numbers on the graph?
Android.
If only there was a way to simply copy/paste the app version. I'll try not to make a mistake...
2.6.0.230906.39816a
Nothing newer available in play store.
Android.
2.6.0.230906.39816a
That’s my android version too, on my Moto Edge Fusion 30. Try at least clearing the app cache if not deleting and reinstalling it. Plus a reboot of the Pro wouldn’t do any harm. You might lose presets/ network stream settings though (not sure though tbh)
I mean the behavior with Q factor.
Graphs are not visible on android.
Reset button seems to work as undo rather than reset to defaults.
