Asking for a friend, really, who bought a Pro Plus and does not like forums ;-)
No answer from me because lack of knowledge. Can this, his curve result in a recommended setting for WiiMs 4 band PEQ? At least as starting point. His main musical taste is what he calls Classic Rock. He uses the dac of the Plus what feeds a beautiful vintage Marantz monster receiver from the 1980s and my old Rogers Monitor Ones.
Solved, thank you. Should try it also.HouseCurve can give you the 4 PEQ settings to install in the WiiM app - it’s ages since I used it so can’t recall the method.
Strange, I'm using it on a dedicated iPhone 6s, using an imm 6 microphone and taking a couple of averaged measures, one at right ear and other at left ear level, then corrected with mini PEQ, following suggestion of house curves.I’d like to try HouseCurve but can’t install it on my iPhone 7 Plus. Even though it’s up to date, it needs a newer version of iOS
I’ve literally just tried to install it again and it says I need iOS 16.1 minimum. My phone is up to date and running iOS 15.8 so it just won’t installStrange, I'm using it on a dedicated iPhone 6s, using an imm 6 microphone and taking a couple of averaged measures, one at right ear and other at left ear level, then corrected with mini PEQ, following suggestion of house curves.
It worked very well but soon I switched to Dirac, it becames another game...
My 6s is at 15.x. I installed house curves time ago, maybe meanwhile they updated the app, changing prerequisites. I should keep in mind to not uninstall it...I’ve literally just tried to install it again and it says I need iOS 16.1 minimum. My phone is up to date and running iOS 15.8 so it just won’t install
Tried Bluetooth?Any tips for getting the Sweep tone to play out of the Wiim?
I have disabled fades and anything else I can think of...
Perhaps I need to set it to 44.1 k ? output? I dunno - I have emailed support.
the sleep tone plays out of my kitchen HomePod Mini's though!
No, Airplay isn't Bluetooth, they're different wireless protocols.Well I selected the Wiim via Airplay - thats Bluetooth right? (I see no chrome cast possibility)
Thanks
Yes I would not delete it if I were you as I really don’t think you could install it now on these older iPhones. Unless, because you have had it already it saves to the cloud?My 6s is at 15.x. I installed house curves time ago, maybe meanwhile they updated the app, changing prerequisites. I should keep in mind to not uninstall it...
Doh! Of course. It worked instantly!No, Airplay isn't Bluetooth, they're different wireless protocols.
