D dbrenster New member Joined Apr 16, 2024 Messages 2 Apr 16, 2024 #1 My wiim has a flashing red light and no sound is going to speakers. I assume this means the unit is dead.
G Griff Major Contributor Joined Oct 22, 2022 Messages 128 Apr 16, 2024 #2 Try a factory reset. Hold down the play button until the light goes off. Worth a try
D dbrenster New member Joined Apr 16, 2024 Messages 2 Apr 16, 2024 #3 Griff said: Try a factory reset. Hold down the play button until the light goes off. Worth a try Click to expand... Thanks I tried that more than once In addition to no sound my phone constantly needs to reconnect...
Brantome Moderator Joined Oct 20, 2022 Messages 5,730 Location Scotland, UK Apr 17, 2024 #4 Raise a ticket to WiiM thru the settings/ feedback route in the WiiM app. I’d also contact your retailer as depending on where you are, the device may still be under warranty.
