In wall controls?
Jan 26, 2023
6
Have a bunch of WiiM Pros. Looking to centrally locate them and setup separate zones in the house. Anyone find a way to add networked wall controls to these things? Audio volume control and possibly even now playing controls? Looking for a rotary knob styled control.
There is a way to install an inexpensive smartphone or tablet on the wall. Charge them regularly using smart plugs. I don't have any other ideas for now.
You may be able to use the Bluetooth volume knob available on Amazon.
(However, you can only control one device or one zone.)
I got that, looking for a dedicated interface. Thanks
The wiims have an api that can be called over https. If you want to go fully custom. Make a webpage that controls them and open it full screen on a pi attached to the screen inside the wall?
