Innuos Sense and Wiim Pro
Mr_J
Aug 2, 2023
Tonight by accident I found out that the Innuos sense App that I use with my ZenITH mk3 in system 1 will also output and control my Pro in system 2.
I'd been using the pro in system 2 for most of the week, however I transferred to the main music room this, evening and was trying to figure out why the ZenITH whilst showing in Sense that it was, playing was not outputting sound to my main rig. After dicking about checking connections etc (had a cable tidy session earlier today) I noticed the speaker icon (bottom right corner was at 68 instead of 100 so decided to adjust it, when its sub-screen popped up, it showed the Pro with its check box ticked (not seen that before) swapping device checkbox gave me back output to the main system.
Anyone else using a mainstream device and App that gives the option to select a Wiim device as, an output option?
NOTE: I don't have, and have never used Roon, though both devices are Roon capable.
