In my book 40 m² is a large room ...
What exactly are your speakers? Speaker sensitivity numbers don't tell much, unfortunately, if the manufacturer doesn't state how it was measured. Everything else being equal, a 3 dB higher speaker sensitivity saves you half the needed output power.
Should you really feel like your missing power the most cost efficient solution in most cases is to simply add a powered sub. This relieves the amp from feeding the most power hungry bass region and can noticeably improve the sound quality with 2-way speakers (because the WiiM Amp will no longer feed them the low bass).
