Line-in to Coaxial on Pro Plus (Solved)
yannchris
Oct 11, 2023
19
Brittany
I'm currently playing an analog source connected to the Line-In input of my Wiim Pro Plus.
Unfortunately, I get no sound from my active speakers connected via Coaxial.
What to do?
Kind regards,
Yann.
What to do?
Kind regards,
Yann.
Sorry for my may be silly question. This "analog source" eventually is a turntable? If so with internal phono pre-amp? Or via an external phono pre-amp?
You are right, it's a turntable.
The line-in of the Wiim is connected to the tape-out of a vintage system, so the preamp is built in the amplifier.
So Wiim can distribute FM, Phono and Tape to the recievers.
What to do?
Kind regards,
Yann.
Are the audio outputs and audio inputs in the WiiM app set up properly?
Also, can you hear the test audio for the coaxial output resolution in the audio settings? If you can't hear the test audio, set it to match the input resolution of the active speaker.
