Pro plus and Roon and DSD
sydlin
Nov 10, 2023
5
Firm updated on my pro+, connected to ifi pro iDSD. Roon the DSD file shows pro+ actually converts DSD to PCMScreenshot_20231221_211701.jpg
It doesn’t support native DSD only up to 192/24. Wiim need to sort out their bad marketing as it’s confusing all users. Stating that the DAC supports DSD and higher PCM, when their software doesn’t and downsamples is not good practice.
Isn't that Roon doing the conversion before it gets anywhere near the Pro Plus?
That’s because the Wiim reports that’s all it supports which is correct. It also doesn’t support DoP so had no way of putting out via Spdif regardless.
I agree WiiM should make a clear statement as to what they’re doing about DSD support on the Pro Plus
For any DSP it will always convert to PCM so as it has a digital volume I imagine it always does, but setting to fixed should negate that.
