Stupid question, help would be really appreciated!
cooky560
Jan 17, 2024
279
I have both a Wiim Amp and a Wiim Pro Plus. The Amp is connected to my bedroom system, the pro plus to my main hifi.
Can I send the stream to both wiim devices at the same time, and if so, how?
Wiim app, devices screen.
Press the paperclip icon next to one of them; add the other to it to create a group.
Play something to the first one.
They will now appear as a single item in the devices screen.
Press the paperclip on that 'device' to ungroup them again when done.
WiiM Home App, tab "Device": Hit the link icon (two chain elements) of what you want to be the master, then select the other WiiM device from the list displayed at the bottom of the screen. That should do the trick.
WiiM groups are not (yet) permanent, though.
  • Like
Reactions: PA3
Link, paperclip... tomato (tomayto), tomato (tomahto)...
A paperclip links pieces of paper... ;)
Small icon, old eyes!
This icon means simply "link" ;-) noticed too late that this wisdom was already stated.
