SpacePilot3000
- Joined
- Dec 5, 2023
- Messages
- 15
Since today (10 April) Tidal has merged High/Plus and due to this fact, subscription is visible as High in Wiim. Unfortunately due to that change, max bitrate is 44kHz/16bit. Please fix it
What happens if you log out and then log back in? I suspect that you will also be limited to high so maybe you do not want to try.Sorry, eventually I understood something wrong. This is the look in the WiiM app
Did it before I postedWhat happens if you log out and then log back in? I suspect that you will also be limited to high so maybe you do not want to try.
I hope it is because app was not updated to reflect subscription changes in TidalI have just signed up to a new Tidal subscription and using the Wiim app it seems to be limited to 16bit/44.1KHz. With Tidal Connect, high res (FLAC and MQA) works fine.
You have/ had a Hifi Plus subscription? Maybe it has not yet changed to the new subscription?Did it before I posted
You have/had the Hifi subscription?I hope it is because app was not updated to reflect subscription changes in Tidal
Please submit a ticket to WiiM via the settings/feedback section in the WiiM Home app so they can fix it. This is primarily a user community forum, not a route to supportSince today (10 April) Tidal has merged High/Plus and due to this fact, subscription is visible as High in Wiim. Unfortunately due to that change, max bitrate is 44kHz/16bit. Please fix it
Hopefully, the app will have been updated by then.Lets see what happens on the 17th once my subscription is renewed ;-)
