Wiim Mini and Tidal - long load times
d3vil0
Feb 4, 2024
Hi, maybe someone will help :)
I've got a problem with long loading times on Tidal using Wiim Mini. (newest Firmware version)
I'm using Wiim App to play Tidal music on my Android smartphone.
Both Wiim and Android are on fast 300 Mb/s internet with very good connection to WiFi on 5Ghz.
When I connect to Wiim for first time (fresh open Wiim App) Everything works fine. New songs loads almost instantly.
When I leave it to play for a few minutes and get back to Wiim app, when changing songs - it takes up to even 15 seconds to load the song, for now on, every song takes a long time to load.
When I close permanently Wiim app and open it up again - works fine again.
The only problem is with playing songs/albums i.e Searching songs works like charm.
I've tested also Default TIDAL app via Tidal Connect (Android and MacbookPro) - got same problem.
PC with Windows - Tidal app via Tidal Connect to Wiim Mini - same problem
When I use Tidal (PC, Macbook, Android) without Tidal Connect - works OK
What I checked:
  • I'm Connected to Wiim via WiFi - checked wifi connection - I think this is not a wifi problem.
  • Standby mode on Wiim - Off
  • Factory Reset + all default settings and Wifi 2.4GHz
  • Wiim and Smartphone DNS - 8.8.8.8 + set static IP for Wiim
  • Android do not throws Wiim APP into sleep
  • Android WiFi energy saving - turned off
  • Other Android smartphone tested - same thing.
  • Apple MacbookPro Tidal app + tidal connect to Wiim - same thing
  • When using Tidal app without tidal connect - works just fine.
Problem was with my Internet Router, I've change to IPv4 only and it works.
Looks like Wiim have a problem with IPv6.
