Staffan.Ringesten
- Joined
- Oct 18, 2023
- Messages
- 9
I am an owner of the WIIM Pro. I have a question regarding the depth and sapling rate on the digital outputs and if it would be possible to add a feather.
As it is now, when using the digital outputs you need to choose one of the fixed sample rates (44.1 kHz, 48 kHz, 96 kHz or 192 kHz). For the depth you have two options; 16 bits and 24 bits. Usually, when listening to different sources the depth and sample rate of the signal varies, hence the incoming signal needs to be up-sampled or down-sampled to match the fixed values that you have chosen.
I would very much like to see a feature where you can also select a "pass through" option. The signal would thus pass unharmed to the external DAC. Selecting this option would of course need to “gray out” the options of fixed sample rate and depth.
Is this something we can hope to be implemented in the future?
Regards,
Staffan from Sweden
Regards,
Staffan from Sweden
