Will this setup work with my WiiM Pro?
PremPlus
Feb 21, 2024
5
I've purchased 2 WiiM Pro units, and paired them with 2 of these: https://doukaudio.com/products/nobs...digital-hifi-amp-with-usb-aux-bluetooth-input
I'll be connecting the WiiM Pro units to the Nobsound amps via Aux using THESE
My speakers are already installed and wired, so essentially that part of it is done, I just need to connect the speaker wires into the amps. From the research I've done everything seems to be compatible and good to go. But I thought it would be a good idea to check here in case anyone else sees any issues with my setup.
Thanks very much
