Calibration
rccarguy
Sep 23, 2023
99
Would it be possible for the wiim devices to calibrate levels, distance/phase?
Or add channel level adjustment/test tones like what avrs have. With correct type of noise for speaker and sub (can't remember if pink/white/white noise speakers and sub need different noise)
I understand there is microphone in the unit /remote so perhaps you place that at the listening position, then run calibration setup.
Don't expect umik 1 level of accuracy but sub integration might be improved. Readout for distances would be useful to verify phase, and give advice what your sub should be set to (if you have variable phase on the sub)
Variable phase in app could be handy as not everyone sub has variable.
