Coaxial SPDIF experiment
onlyoneme
Oct 20, 2022
2,260
to get an eye-pattern. An ordinary RCA analog cable used, terminated with 50 ohm and a PicoScope 4444 oscilloscope working with 20 MHz BW.
48 kHz:
96 kHz:
192 kHz:
Any thoughts? :)
Spdif coax spec is 75 ohm if I remember it right. 1.2 m minumum length. Not sure how that might affect your results..
I know, but I was getting much worse visualization when terminating with 75 ohm. Maybe the cable I've used is closer to 50 ohm. No idea what's the impedance usually for analog RCA cables.
A short explanation - I'm trying to figure out how a cable can influence the carrier jitter and noise for different sample rates.
If only it was as simple as that! it would put reviewers out of business overnight.
look at audio science review website for ways of using scopes to see Jitter (and basically how insignificant jitter is in the world of modern Dacs)
  • Like
Reactions: GTS
a 20mhz is not enough for this kind of observations
the rise times of the scope are too long for a relevant observation...
but an example of a really clean 44/16 signal at the output of a drive..
but again on a too limited scope like 50mhz .. the rise time marred by 7ns plus a little the probe ...to do well, you need 350-400mhz mini and adapted probe..i have but..not wiim pro i cant help...
If I'm reading it right, you're showing that the digital signal degradation increases with the increase in frequency?
Isn't that to be expected?
Why? SPDIF frequency for 192 kHz is less than 13 MHz.
Different cable, still 50 ohm, different triggering.
48 kHz:
96 kHz:
192 kHz:
it's just that you don't have enough margin..
the rising edges are tainted by the slow rise times of the 20mhz
(350/20...17.5ns...350/50..7ns etc)
It makes reading a bit clumsy...
etc
no, I have nothing on hand.(but these are square signals..explain the difficulty for a scope without a large margin in bw...)
automatic edge calculations give how many ns?...(x-17.5ns?)
(from memory the example I show was a + 3.5 4ns+7 type of flipflop output...)
but it's not a standard 0.5v spdif output?
ps
I would like to know if wiim has put a transformer in spdif output
but we still don't have a photo.
but if there is one side external dac .. not a problem
It's a standard spdif output but impedance mismatch - 50 ohm termination plus a cable - probably affects a voltage.
I know I won't get a square wave representation, I don't expect this. But I think the noise and jitter can be still observed on the pattern.
