Same as mine. Time to reinstall the app probably.4.8.527256
But no luck.
Edit: wrong security settings in LMS. Everything is fine.
surprising that you did not receive the non-beta version, "modified" in view of the efforts you produce for wiim and to be able to observe the differences or not between beta and finalized..same as mine. Time to reinstall the app probably.
But no luck.
Soonthank you...
classic..
but:
ap32?
smpte? ccif?
--- thd-thd+n vs frequency?
somes sensibles differences with differents filters?
Soon
For now I can say that there is no difference in THD vs frequency sweeps for all slow and fast filters.
at high frequencies it is logical...but let's hope that there is really a difference under 1k in thd...etc with the "modified" version..Everything above is about my old pre-prod Pro Plus, it's the only sample I got.
No difference in distortion levels between filters at low frequencies. Changing the filter will not improve the performance in this case.
And a different story with high frequencies as shown in CCIF test due to different attenuations levels and strong aliases for the NOS filter:
