Gscott
I'm curios if anyone else experiences "Device Not Found' occasionally? Happen to me just yesterday. I had listen to music all day the night before and into the evening. Stopped the music, closed the WiiM app, shut down the Ipad. Got up the yesterday, turned on the Ipad, waited for the wifi symbol to appear, turned on the DAC...coax imput flashing which is an indication there's going to be an issue, fired up the WiiM app..."device not found." Followed the on screen instructions which did not work. I was forced to do a factory reset. It took several attempts before "found a new device near by" appeared. After I got to the "lets get started" screen I noticed during setup defaulted to wifi instead of ether net....having gone through this before, I halted the setup process, unplugged the power to the unit, waited about 10 seconds, restored the power and all went well, including using ether net. I've had this happen a few times after I initially set the WiiM up after purchase. The occurrences became fewer and fewer with each app or firmware update. It's not a big issue but you do lose your presets and logins to music services. Am I doing something wrong or is to be expected from time to time? Just curios!!!
