First disconnect all existing bt from the Sony.
Change to pairing mode.
In "audio out" in the WiiM app choose bluetooth and let the app search the Sony.
Those are detailed instructions, and the first two lines pertain specifically to your headphones.
You would need to refer to the Bluetooth pairing instructions for your specific headphones there, to put them in pairing mode.
The last line is self explanatory, use the WiiM Home app to choose Bluetooth as the Audio output, then search/scan for your Sony headphones to pair with once you've put them in the above mentioned pairing mode.
Unfortunately since WiiM does not support anything but the SBC and AAC codecs for Bluetooth, you will not be getting the full resolution those headphones are capable of when using Sony's LDAC codec, which is currently unsupported by WiiM.
