Hello, I'm at the beginning of the multiroom music journey and I'd like some advice. Here is what I already have:
1. Kitchen: A set of Edifier bluetooth speakers, with a wired sub (the Edifier has a 3.5mm input - but I usually connect by BT from my phone)
2. Basement: PA system (Soundboard with powered speakers)
3. A small portable bluetooth speaker (has a 3.5mm input)
4. A Mac Mini, iphone, ipad, Android phone, Android tablet, that can be used as a player
5. Everything is on wifi with no ethernet wiring in the house
So you can see I don't have a lot
I am looking for a cost effective way to stream the same audio to at least 4 places - the Kitchen, Living room, Basement and a portable speaker.
How many Wiim devices do I need?
Should I consider getting some speakers that are Wiim compatible?
Any advice would be awesome!
