J joffy1780 Major Contributor Joined Mar 30, 2023 Messages 155 Oct 21, 2023 #1 There are several apps which can sync compatible Phillips Hue lights to your music and I would love to see this integrated into the Wiim Home App. Upvote 0 Downvote
S Smartplug Major Contributor Joined Oct 20, 2022 Messages 1,099 Oct 21, 2023 #2 Maybe you want to integrate smart toaster that you can toast by wiim app so you can listen and eat same time.
J joffy1780 Major Contributor Joined Mar 30, 2023 Messages 155 Oct 21, 2023 #3 Smartplug said: Maybe you want to integrate smart toaster that you can toast by wiim app so you can listen and eat same time. Click to expand... Well no, I usually have parties in the evenings and toast in the mornings.
