AdieH
Nov 25, 2022
11
Hi all,
Cheers,
Adrian
onlyoneme
Oct 20, 2022
599
If a network (WiFi) or bt source is selected, then clicks are present with any output option (Bluetooth speaker does not consider, there are separate problems with it).
If the AUX input is selected, there are no clicks on both output options.
This is one of the tests on a simple build. Bt-WiiM-aux. The portable speaker has enough gain to show the problem. Clicks sound much more unpleasant on a large audio system.
I do not face such behavior with my Mini, fixed volume, no EQ. Tested with AM, Tidal and Spotify.
cc_rider
Oct 20, 2022
156
I don’t have the issue either, using an RME DAC, which is extremely well engineered, not targeting the audiophile crowd.
kate25
Oct 29, 2022
17
Perhaps this is a problem only for some devices.
For the aux output, I can use static volume, then a small gain will be required from the amplifier. The problem will be unnoticeable. Although it does not disappear anywhere. But I prefer to adjust the volume of the streamer, especially when used in a smart home setup.
There is a strange situation with the optical output, there have been attempts to fix it over the past three updates. Improvements are possible for some network playback sources. But the problem has not been solved globally. And worst of all, when wiim is in a slave state, clicks are present.
Smartplug
Oct 20, 2022
257
Since majority of us don’t have issue, you may have defective unit or your dac is the issue. Do you have another dac to try ?
Klipscher
Nov 7, 2022
87
Do you notice clicking all the time, or only when switching tracks? What music service are you using? Does it happen btw every track or just when switching to a different bitrate track?
Klipscher
Nov 7, 2022
87
Zero click!
Trying figure out what's different in setup that's causing many to experience this popping sound. Mine only happens when switching bitrate on tidal. It be helpful to know what music service people are using that are or are not experiencing this problem.
Smartplug
Oct 20, 2022
257
I have amazon, quoboz and tidal. My dac smsl do200 mk ii. Zero problem and sound great for sub 500.
Smartplug
Oct 20, 2022
257
So full mqa support = no issue. Thanks for responce
I had topping e50 before and in the early days when wiim release mqa core beta I had nothing but problem such stuttering and pop noise. I took a chance and purchase a higher end dac problem solved. On my dac display mqa it has different mqa color like blue, green pink.
AdieH
Nov 25, 2022
11
It happens for me on both Spotify (using Spotify Connect) and Qobuz (thru the WiiM app).
AdieH
Nov 25, 2022
11
It is a part Dac part Wiim issue.
I had the same problem with my Theta Dacs using a BD player as a source, some BD players would create a loud pop or static sound when changing tracks, but on different BD players it would be fine.
After some research I found that the Theta Dac doesn't have a signal mute to turn off the signal when skipping tracks, plus the BD player doesn't either, so what happens is when you skip a track instead of muting the signal for a split second the signal stays engaged and you get the static coming through in-between the next track starting while thf signal locks again.
Either your Dac or source needs to mute the signal when skipping a track, as long one of them does it, it won't give that noise issue, so I'm sure Wiim could try fix it with an update.
Hi Ryan - I think this is probably rights. I've been doing some research around this issue and this makes a lot of sense.
I'm wondering if I would have the same issue with Coax, but I don't have a coax source to test it with.
In any event, I'm going to contact Denafrips and see what they say.
WiiM Support
Administrator
Nov 6, 2022
182
Hi all,
Cheers,
Adrian
Hi Adrian, can you confirm the clicking/pop noise also happens with the Spotify connect?
There may be a click if the sample rate is changed between the track since your DAC need relock the optical signal due to different sample rates. If we do the bit perfect decoding (the audio resolution of the output matches the audio source without resampling), it may be inevitable.
However, for Spotify Connect, since most track has the same frame rate and bit-depth, there shouldn't be click or pop sound. If you still have this issue, please send us a feedback with the App, we'll look at this immediately. Thank you!
WiiM Support
Administrator
Nov 6, 2022
182
Hi Kate25, thank for your Youtube video. One thing I'd like to point out, can you please use the WiiM Home App and test it again? The App you're using seems to be another OEM app we made for other brands. Thank you!
WiiM Support
Administrator
Nov 6, 2022
182
I too have the clicking problem between tracks on aux port. Happens only when manually changing track position or prev/next song. I'm on firmware 4.6.503558
Hi SnowDog, which volume you're using when you have the clicking problem with your aux port? Can you please send us a feedback whenever you have this issue? Thank you!
onlyoneme
Oct 20, 2022
599
There is an SPDIF relock even if sample rate doesn't change actually. Spotify Connect and Tidal Connect are exceptions when relock is performed only when needed (Tidal) or no relock at all as sample rate never changes (Spotify).
WiiM Support
Administrator
Nov 6, 2022
182
Hi onlyoneme, this's interesting finding. I'll raise it with our eng team and check it out. SPDIF relock shouldn't happen if the sample rate doesn't change.
