AdieH
Nov 25, 2022
12
Hi all,
Cheers,
Adrian
It would and I have contacted Topping but I see similar complaints on this thread. Same issue which, in my case I guess gets amplified when using XLR.
Reading some posts above the noise is related to shutting off and turning on the clocks which is on the Wiim.
Do you have any other source with digital output you could try into the Dac instead of the WiiM to see what happens,
No noise with any of my 4 transports. Now, those are fixed sampling rate whereas the Wiim changes according to the source track.
Wiim sent me a firmware update to try. Great response from Wiim!!!!
