Pro update V4.8.605650
Do you want to put a volume limit on each output instead of each input? 😳
I thought that the fixed volume function of each input was a function to eliminate the volume difference between inputs. 🤔
Yeah, the current per source volume was to deal with the different input levels from say a TV over HDMI and a WiFi stream to save people reaching for the remote when switching input caused the volume to blast out loud. I can see a need as I explained above for different outputs having different settings, although I do admit it might be confusing if you wanted both input and output presets and the WiiM having to decide which had precedence.
