media room
- Joined
- Apr 13, 2023
- Messages
- 13
When I try to stream playlists from Amazon music HD, my mini will only stream the first few songs from the list. Is there a solution?
Don’t know what you mean by streaming Spotify playlists from the WiiM app, all it does is open the Spotify so that’s exactly the same as you opening and using the Spotify app…Not really but I now know it can stream playlists properly from the Wiim app and Spotify app while doing neither with Amazon Music HD.
It works fine just using Amazon Music Unlimited only. The problem is only when using the Wiim Mini.Do you have any echo devices you can try casting to from the amazon music app to see if you get the same issue there which would then point to a bug in the amazon music app? If you try just playing the playlists in the amazon music app, do you get the issue or is it just when you cast to your WiiM device? Also, for clarity, which amazon music services are you using - free, Prime or Unlimited?
So it doesn't matter what I mean as it works as it should unlike Amazon Unlimited. I am a newbie so please forgive me for explaining something wrong.Don’t know what you mean by streaming Spotify playlists from the WiiM app, all it does is open the Spotify so that’s exactly the same as you opening and using the Spotify app…
So you can use the Amazon Music app and cast to the Wiim Mini as described above using AlexaCast, but it’s not working when you use the WiiM home app and choose Amazon music there?It works fine just using Amazon Music Unlimited only. The problem is only when using the Wiim Mini.
No. I can just use it not involving the mini at all. Any way I use it with the mini it will only play the first few tracks in any playlist I try. If I just play from songs it will work correctly but not from playlists.So you can use the Amazon Music app and cast to the Wiim Mini as described above using AlexaCast, but it’s not working when you use the WiiM home app and choose Amazon music there?
Thanks. In that case, I guess your best recourse is to submit a ticket using the feedback section in the WiiM Home app to allow WiiM to investigate your device logs and hopefully find a solution.No. I can just use it not involving the mini at all. Any way I use it with the mini it will only play the first few tracks in any playlist I try. If I just play from songs it will work correctly but not from playlists.
