sbalbuena7
- Joined
- Feb 10, 2023
- Messages
- 3
I2s and usb output, with bluetooth 5.3 LDAC
Yes, Sony bluetooth LDAC codec is a good idea. My ifi Zen Blue with LDAC is almost as good sounding as the Pro.I2s and usb output, with bluetooth 5.3 LDAC
Not specifically a product but what about a plugin for the StreamDeck?What products would you like to see based on what you've experienced so far?
You should stick to your current product and perfect the UI and the features it offers as well as the hardware.What products would you like to see based on what you've experienced so far?
Given WiiM allows use of the full Amazon Music app to cast bit perfectly up to 24/192 to a WiiM device, and the WiiM Home app Amazon Music interface probably does all that the Amazon api allows, what further integration do you envisage?…amazon HD music integrated to allow greater accessibility into Amazon's IU.
Yeah that's what I mean, the product is pretty good - the only thing that you could do is put a screen on it and give it a better finish.Given WiiM allows use of the full Amazon Music app to cast bit perfectly up to 24/192 to a WiiM device, and the WiiM Home app Amazon Music interface probably does all that the Amazon api allows, what further integration do you envisage?
Do you have any more details on the aune product and its Amazon Music development? It’ll be interesting to see whether it’s another Bluesound node type development where they can’t cast bit perfect from the amazon music app, or whether it’ll be seen as a competitor to WiiM in that area. CheersAs I mentioned before: For nearly all wishes, beside HiRes Amazon (where I am waiting for a product from Aune which is on his way) are higher priced items all over the market.
No digital output or output limited to 44.1/16? Yes, almost the same...A company like Arylic has almost the same product as WIIM. Their S10 only lacks digital out. S50 Pro+doesn't have chromecast but better dac chip than WIIM. I Also Found Dayton Audio that is similar devices to Mini and pro. It's app is compatible with WIIM I found.
The WIIM Mini was limited to that too until may 2022 or so. Not up to date with the current state of it (S50pro+).No digital output or output limited to 44.1/16? Yes, almost the same...
