Linkplay multi room might only support 24/48, but here‘s a screen showing 24/192 is supported on a ChromeCast group comprising My WiiM Pro and WiiM Pro Plus using BubbleUPnP - the WiiM Home app also shows that resolution.But I don't think that in a MRM setup the sound quality is an argument as WiiM only supports 24 bits/48 kHz sampling in such a setup, while Chromecast TV supports 24/96.
I approve the Gospel according to Achim- Cheap AND omnipotent does not work.
- Use items for their strong abilities. In case of WiiM it is the possible great sound quality.
- For multi-room better or at least simpler solutions exists for long. Sonos always work.
- Make the research what an item can deliver BEFORE buying it.
- WiiM and YTM or Spotify with its poor sound quality is a mismatch. Casting pearls before swines.
I don’t love CD and i have never loved them. That said, antes streaming my listenings where 99% vinyl.Personally this digressing is one of my most liked "features" in this forum
The "Roon Core" is not a device, but the software itself. You have to install it. Nearly every PC, even a not longer in use notebook is fine for it. But this PC has to run always you use the software. If this PC is used for other things it can be a little nerving. So we, my wife was the crusader for Roon, bought the Nucleus+. In between and with hints out of this forum I as an absolute noob in IT managed to "build" a NUC Rock which at the end costs less than 350 €. All the necessary information you will find in the net.
Qobuz or the others? This sometimes is kind of a confession. For me it is ok, I find every album I want. But that may be my personal case. Spotify claims still to have the biggest catalogue. I am more in classical and jazz, in rock more with the old heroes. So for me it is perfect. And the sound quality is the best you can get from streaming services.
Last, as I still want to own most of my music I love and buy LPs and CDs. Although my frequent presence in this forum may show it other I still use ~ 50% Vinyl, 40% CDs or ripped files and streaming is the rest. Easy, cheap and convenient to avoid wrong purchases.
So, another misuse of that very nice forum.
@Achim1811@Maurizio
You know I need physical activity
What I have to confess is that streaming saves me money. The purchases getting less and lesser.
Me and some engineers I know are working very hard on a solution where masses of speakers on rails surround me. This Dolby Atmos failed, we will do it better. Stay tuned, you will be informed.@Achim1811
Yes, i know so…keep moving more and more
Unfortunately listen to music, through loudspeakers, needs a fixed point or you could listen to marching up and down the room.
Thanks so much sir. Obliged.Me and some engineers I know are working very hard on a solution where masses of speakers on rails surround me. This Dolby Atmos failed, we will do it better. Stay tuned, you will be informed.
