If that’s the case it’s fairly useless.Once I learned that Amazon restricted the user's library to 100 tracks. I first understood 100 albums, but indeed it meant tracks. May be something related?
I would immediately cancel useless Amazon
Thanks for this. It’s bloody stupid of them, just means I stay with Qobuz. Surely it’s more cost effective to fix the issue, they obviously don’t need the money.@III
I found the answer I got in May.
It's a known restriction that Amazon apparently won't address - see the WiiM known errors table, first entry - https://faq.wiimhome.com/support/solutions/articles/72000572637-wiim-mini-known-issues
If they could fix the artist sorting for A-Z for Qobuz I would be even happierMay be they want to keep it not too easy
Anyway, my choice is also Qobuz from the first hour they appeared in Germany. AMHD is more or less for my granddaughter who loves to create playlists for grandpa . Little issues one will find in every streaming service, depending to the personal priorities. Luxury problems I think.
Doesn’t sound like it’s the same issue if only one album is showing. There may be a general restriction in the amazon music api to only returning a max of 100 results to a query whether that be favourites, playlist or whatever, but I wouldn’t see that only returning one album@III
Doesn’t Qobuz have its own limits and quirks?It’s a shame, I thought it was a possible cheaper replacement for Qobuz but it’s not to be.
I haven’t used alexacast beforeDoesn’t Qobuz have its own limits and quirks?
Anyway, using the Amazon Music app you can cast bit perfect up to 24/192 (which you can’t with Qobuz), so use that rather than the WiiM app.
Worth using. I’d go as far as to say that cast/Connect mechanisms are the way to go as they offer the full range of features available for a streaming service rather than the reduced set that they generally make available thru their third party APIs. Plus WiiM is unique in supporting bit perfect casting up to 24/192 from the Amazon music app. However, it must be said that AlexaCast is not available in all regions where Amazon Music is - Poland for example. Spotify and Tidal also have their Connect features, while Qobuz has supposedly been working on their version for some time.I haven’t used alexacast before
The only option I have to cast with is Airplay, can’t see anything for alexacast.Worth using. I’d go as far as to say that cast/Connect mechanisms are the way to go as they offer the full range of features available for a streaming service rather than the reduced set that they generally make available thru their third party APIs. Plus WiiM is unique in supporting bit perfect casting up to 24/192 from the Amazon music app. However, it must be said that AlexaCast is not available in all regions where Amazon Music is - Poland for example. Spotify and Tidal also have their Connect features, while Qobuz has supposedly been working on their version for some time.
Have you enabled Alexa in the Wiim home app?The only option I have to cast with is Airplay, can’t see anything for alexacast.
I have and also changed the location to UK, might just take time to update.Have you enabled Alexa in the Wiim home app?
