weiland555
- Joined
- Aug 15, 2023
- Messages
- 2
Some early reviews mention DSD capabilities in the Pro Plus's new DAC. Are any such features available at the moment? Can the internal DAC decode DSD?
No mention of this from WiiM themselves - raise a ticket via feedback in the WiiM home app to ask them directly.Some early reviews mention DSD capabilities in the Pro Plus's new DAC. Are any such features available at the moment? Can the internal DAC decode DSD?
A-ha. Will do. Thanks.No mention of this from WiiM themselves - raise a ticket via feedback in the WiiM home app to ask them directly.
If you have the licensed version of MinimServer you could try changing the advertised mime type as described here.2nd test case with the internal DAC was to select a DSD file via the DLNA-Server Minimserver (2.2) from the Musicshare section in the Wiim app. The artwork of the file is shown, but the file does not start playing. I've tried with several different DSD-files (.dsf). Any PCM-file (e.g. FLAC 16bit 44.1kHz) plays without problems (obviously)
SeeIf you have the licensed version of MinimServer you could try changing the advertised mime type as described here.
I don't have any DSD files, but if you can't test that change I'd be happy to if you can supply a heavily truncated track.
Thank you, I was aware of the mime type issue and had created Minimserver-profiles with and without the mime type string. During testing I toggled between the profiles, but it did not impact the (negative) results.If you have the licensed version of MinimServer you could try changing the advertised mime type as described here.
I have a Pro Plus but don’t use DSD, so I’ll pass WiiM have said their engineers are looking into firmware support for DSDI filed a ticket for this, too. Everyone else who own a Pro Plus should.
It took me a minute at all, but now I have itAh, so no difference Atoll?
Sorry, couldn't help myself…
You have broken DSD there using volume control on the DAC you can’t apply DSP to a DSD stream.Just tried again to hear any differences. My good old Atoll with SACDs sounds absolutely great.
The same album as DSD file, Qobuz or CD sounded exactly as good. May be Golden Ears will hear something
And that is the way DSD was handled this morning:
