Mike in NY
Definite circle jerk.And btw...the Kindergarten ASR is since a while only a place for measurement onanism for mostly first semester students.
NonsenseNot always, remember the deeply flawed review and measurements of the Sonore microRendu?
While there has been revisionist history applied there to cover up the original botch job, that review concluded the mR could not be recommended because it was not bitperfect, and caused an 8dB rise at the analog output of the USB connected DAC.
All of that was of course completely false/inaccurate, said a lot about the competency of the reviewer, and also revealed an obvious agenda/axe to grind, as well as a failure to listen to the mR at all, as an 8dB rise surely would be easily/clearly audible to the most casual observer.
Also false was Amir's assertion that the iFi iPower was the "included" power supply with the microRendu, when in fact it was just one of several options offered by Sonore, who sold that unit by default sans PSU. Once corrected on that misrepresentation, he then tried to call the iPower Sonore's "recommended" PSU, which was also false, then tried to shift the goalposts entirely by turning the whole embarrassing debacle thing into a scathing indictment of the iPower itself.
Wow was there egg all over Amir's face when it was determined his test setup was deeply flawed, including Windows Media Player (really?), with the dithered software volume control enabled. No thats not bitperfect, not through the microRendu nor any other network endpoint either.
Microsoft, Windows Media Player, buying then immediately retiring HDCD... not exactly the stuff of audio legends there.
How about the steadfast backing of that complete crock of BS known as Master Quality Adulterated? Almost caused a mutiny among the faithful over there, didn't it?
ASR = groupthink extraordinaire, which is too bad because there are various good/knowledgable people posting there.
if it is a story of jitter at the output of the mini which will be improved.. it is however easy to measure and check...Well anyway . I don’t pretend to be an authority when my background is in finance and not in sound engineering/ electrical engineering. My guess is that cleaner current feeds the clock and the optical converter in optical out therefore jitter is reduced . I did back and forth with the Apple charger . I mean you don’t even have to try to hear the big difference
Hasn’t this old canard (pun intended) been gone over before ad nauseum - jitter doesn’t really matter on the WiiM’s digital outputs and even if it did, it’s more than handled by any competent external DAC?if it is a story of jitter at the output of the mini which will be improved.. it is however easy to measure and check...
At least 4 cases for different chargers scenarios:Well anyway . I don’t pretend to be an authority when my background is in finance and not in sound engineering/ electrical engineering. My guess is that cleaner current feeds the clock and the optical converter in optical out therefore jitter is reduced . I did back and forth with the Apple charger . I mean you don’t even have to try to hear the big difference
Look at the reports how the charger is supposed to affect the digital output and ask yourself if we are talking about competent devices in the chain... If we are not considering an illusion of course.Hasn’t this old canard (pun intended) been gone over before ad nauseum - jitter doesn’t really matter on the WiiM’s digital outputs and even if it did, it’s more than handled by any competent external DAC?
I agree that the charger can affect other devices indirectly .At least 3 cases for different chargers scenarios:
- charger affects the Mini and the result can be shown directly on the analog output for example
- charger affects the Mini and the result can be shown on the toslink output but measured through the receiver - so receiver's abilities to handle the incoming signal matters, like jitter suppression
- charger affects any other device in the audio chain through the Mini output
- charger affects any other device in the audio chain indirectly
Fourth case is unrelated to the Mini but it's related to the presence of low quality / outdated / vintage devices.
Third one can happen for the analog output when some issues like ground loop exist in the chain.
For the first case I've noticed a measurably significant difference only when the Mini was in idle state. No difference or insignificant one when it was playing anything.
Second case has been mentioned by me previously.
A simple path:The opposition covers also things you have supported in the past ,as for instance the example of hard drive in the thread about optical cables and the cable importance using again using the argument of bit perfect . But for now, as you can see from the partial screenshots, it states that interpolation - which is a form of error correction of the dac, is distortion. How will that be depicted on a graph? Would you able to discriminate or it will seem bit perfect? Again about jitter, if the dac will follow similar techniques to correct timing errors then it would be again a compromise, as it will again estimate the correct shape of waveform in order to interpret the correct order of 1s and 0s . It shows that error correction techniques have costs.
So you can copy and paste the waveforms input and output and they will 100% overlap, correct?So how many devices pass this test? I assume most... Therefore I am delusional and I hear voices. Ok I am out...A simple path:
raw uncompressed audio file > streamer > audio stream over toslink > receiver > audio stream over usb > PC > raw uncompressed audio file
When audio file at the beginning is bit equal to the audio file at the and, we have a bit-perfect audio chain. That includes a time factor. And that also means that the jitter has been rejected successfully to get "a perfectly re-created sine wave" in the digital domain. Again, it's the Mini scenario when connected to the properly designed DAC.
If you say so, bye bye.Therefore I am delusional and I hear voices. Ok I am out...
Yes exactly… But I prefer the bing gpt 4 powered ai anyway@steadyshot
Take this for what it is. Long time ago Thackeray wrote the standard book: Vanity Fair
Would WIIM mini or Pro benefit from a lineair power supply instead of a traditional power adapter. Would it improve the
There's no doubt that the sound has a big improve if you have a Linear power supply instead.Would WIIM mini or Pro benefit from a lineair power supply instead of a traditional power adapter. Would it improve the sound quality?
