And since we are here, would it be possible to also remove similar delays when switching between the presets?Hi Adias,
Thanks for the report. We can remove this 3-sec latency when there's no input switch. This 3-sec VAD detection is necessary when you're not in the SPDIF mode since you want to be sure there's a valid signal coming in then switch to that mode. Thank you!
