PEQ or shelf filter to block frequencies under 40hz?
Due to their working principle neither a PEQ nor a shelf filter can efficiently block all frequencies below 40 Hz. That would require a high-pass filter. You could lower the level of frequencies below 40 Hz with a shelf filter or reduce frequencies around 40 Hz with a standard PEQ.
Why do you ask? What's your use case?
