CrystalGipsy
- Joined
- Sep 13, 2023
- Messages
- 243
My issues are on android but could be an issue on iOS as well.Is it possible that this is not available for iPhone users?
. Yester day finally i got to play with PEQ on my Pro and what your saying applied to the fullest. I have a nasty room node @ 38 hz and when i adjusted the PEQ to that frecuency by -2 db and setup the LS tap; low base rumble that i has was Gone.. I have a simple Kanto 8 sub and stats show it goes to 37hz. My jaw Dropped with the vast change it did (also my first time using a PEQ). Also did a reduction in ouput @ 250hz since my speakers (Triangle Borea 02 5inch midwoofer) comes from factory with a rise @250hz of almost 3.5 db, i assume that was done to give a more punchy base presentation from factory.I sincerly stayed two plus hours listening to tracks that i know accebtuate this node and it was clean fast and punchy base. For me its a game changer!So, PEQ has finally come on mini...
The four band are just enough to compensate two holes in the very low range due to room node resonances, not fixable without unacceptable sub placement.
To be honest, a fifth band would make a more precise intervention but I don't think I'll go to pro for that...
The bass doesn't became boomy or louder, simply it's more complete in character. Switching back an forth, makes the comparison certain and instantaneous.
The improvement is subtle but very effective, making me convinced about to pursuit Dirac or YPAO correction system in the near future...
yesQuestions:
Does the PEQ functionality apply to digital output as well as line-out?
NoIs it output selectable (PEQ on COAX but not Optical)
I’d expect that to be the EQ modified stream but I’m not 100% - one for WiiM to answer I’d say, so raise a ticket to them via the feedback section in the WiiM home app.What's passed in a multi-room setup? Is that configurable/defeatable?
Are there any nuances between Pro and Pro Plus in regards to PEQ?
No problem, that’s what the forum is for…Sorry, new here and I've searched for an hour, I read the FAQ on PEQ but that's not spelled out.
Excellent, thanks! For PEQ on Digital out that's a real feature, just ordered a Pro to experiment with. I'm moving off my Squeezebox's.yes
No
Not that I’m aware of.
Hi, I’ve just grouped my Pro Plus with my Pro and Mini, and I only get the option to control EQ/PEQ on the main now playing screen - I can’t choose just one particular device and control its EQ individually so that would support my assertion that the same EQ’d stream is being sent to allExcellent, thanks! For PEQ on Digital out that's a real feature, just ordered a Pro to experiment with. I'm moving off my Squeezebox's.
Wiim seems like they could be poised to be the next generation Squeezebox I've been dreaming about for 10 years. Build a model with Dirac Live and a nice programmable display (blue VU meters with song title an album cover anyone?) then take my money, I'll put one in every room.
#491547 Question on PEQ
I opened a ticket. I know the feature is new so will be lots of discovery. I'd think they could make that defeat-able pretty easily.Hi, I’ve just grouped my Pro Plus with my Pro and Mini, and I only get the option to control EQ/PEQ on the main now playing screen - I can’t choose just one particular device and control its EQ individually so that would support my assertion that the same EQ’d stream is being sent to all
There are a lot of features and enhancements that might fall into the “pretty easily” implemented class, but that doesn’t necessarily mean you’ll see them soon given the nature of software developmentI opened a ticket. I know the feature is new so will be lots of discovery. I'd think they could make that defeat-able pretty easily.
Yeah, I imagine they've got a super long list of feature requests. I'm happy to have found a company interested in developing this stuff. I love my Mac/iOS stuff but Apple Music lost its soul with every UI change. I was about to go down the Sonos route but I've got old amps/receivers/speakers sitting around, seems a waste.There are a lot of features and enhancements that might fall into the “pretty easily” implemented class, but that doesn’t necessarily mean you’ll see them soon given the nature of software development
Despite my test, it does beg the question if the EQ settings you set on each device prior to grouping are overridden or used when they’re being streamed to in a group. It’ll be interesting to get the word from the horse’s mouth…
For me also?Joint
Given some of your responses, it sounds like you may have an adequate supplyFor me also?
Be honest if it is too muchGiven some of your responses, it sounds like you may have an adequate supply
As long as you’re playing nicely with the other children, as with everyone else, you won’t be put on the naughty stepBe honest if it is too much
