And of course if one buys things it has to do the job.For sound quality don't be so sure, it depends . It is a matter of ergonomics. You buy something and not have to worry about fit...
Red Dawn, analog interconnectMy old Nordost is a Blue Heaven with WBT instead of the BNC with RCA adapters. It fitted
Unfortunate and (un)intended abbreviation?BS Node
And yes, I've got itRed Dawn, analog interconnect
Fitted and sounded absolutely fine on a BS Node as a 'digital' interconnect.
Exactly the same as the (proper) digital interconnect I later put on the Node, hence me trying to use it on the pro at that time.
That pro is now optical, and the Reds are back in analog action.
My Blue Heavens never left the analog realm.
Sadly, my Moonglos never really see the light of night (get it?) anymore as I hardly ever use my CD player.
And....deciding for or against a streamer related to already possessed or wanted cables? Tried my Pro with a lot of my coax cables and not a single one did not fit. No idea with optical.
@rccarguy By the way...Nitro or electric? 1/8 or ?
Yeah, too bad that they didn't come out with a WiiM Pro Studio with balanced Neutrik combo connectors. I bought one Pro Plus as a test and I ended up returning it. I won't be buying another as it just isn't worth the additional cost. If you are going to be putting better DAC in, you should upgrade the signal path to be truly balanced, otherwise is just seems like more decorative icing on the same cake.The pro plus has a little more space around the connector.
Some cables don't fit in the smaller recess in the pro.
I think the pro plus also has a little more space around the rca output terminals.
This is the reason I keep my Pro cause I have a balanced DAC therefore the Plus is not necessary for me. I don't need the Line Input for my use but it must be good with a turntableYeah, too bad that they didn't come out with a WiiM Pro Studio with balanced Neutrik combo connectors. I bought one Pro Plus as a test and I ended up returning it. I won't be buying another as it just isn't worth the additional cost. If you are going to be putting better DAC in, you should upgrade the signal path to be truly balanced, otherwise is just seems like more decorative icing on the same cake.
I’m just wanting a little confirmation.
There’s talk of future upgrades to all WiiM streamers for more bands of PEQ and room correction.
Is the processing power required to handle these in both the Pro and Pro Plus equal? Is it just the DAC and ADC that’s different? Or is there any possibility that the Pro Plus might be able to handle them but not the Pro?
Any input from @WiiM Support or anyone else would be greatly appreciated.
Cheers.
I understand the Pro and the Pro Plus both use a quad core Arm Cortex-A53 64-bit cpu with 512k DRAM, which is double the number of cores and four times the ram the Mini has
I just received my pro yesterday, didn't go for the plus as my Marantz PM6007 has an AK4490EQ DAC, and it appears to be using the upgraded casing with the larger opening around the coax socket. I was also surprised to find a remote control included, which I thought only came as standard with the pro+. Very happy for the £149 paid.You’d have thought that recently manufactured Pro’s would have this too, but I don’t recall anyone having checked or mentioned that.
Guess you meant the pro plusI was also surprised to find a remote control included, which I thought only came as standard with the pro.
