Brantome
Moderator
You're trying to use your LMS instance in effect as a UPNP server which it isn't, with the WiiM Home app as UPNP control point and your WiiM device the player. However, your issue seems to be that the Linux subsystem on your ChromeBook doesn't allow your LMS system to see the WiiM as a squeezelite player (which it is) when you use the LMS browser interface which as said is an unsupported installation. Neither can you use the WiiM Home app as an LMS control point as the LMS server isn't UPNP/DLNA compliant.Super dumb question when you say client you mean in the back end as a way to connect it or an actual interface? I still think I just have an incorrect setting on my lms GUI interface thru the Firefox browser but no clue what it should be or currently is.
I'd try the MediaServer app I mentioned above, or host your LMS server on a supported platform.
