Please keep remarks respectful. Referring to Wiim having a “comprehension problem” is not conducive to a constructive conversation. Plus they have already said that the two products they have in the pipeline after the Pro Plus will have USB out viz.They seem to have a comprehension problem that prohibits them from understanding that request.
but that's not the question here...But that simply does not make the question or the wish obsolete! The one and only missing link to so many actual DACs is an USB out. I would name it silly if WiiM does not go for it. There is no, absolutely no modern streamer in the competition without. May be a tiny inaudible but measurable noise is important for some, a simple well shielded USB out will satisfy much more clients.
Even after having a few Duckstein I am still able to read. So it was indeed the question and the headline of this thread, not the debate if one hears something different with higher resolutions. This field I'll leave you. And if WiiM will present it in the future it is fine. And a comment like "your point makes no sense considering that spotify is only compressed.....not basicly qualitatif" is one of the absolute sort which really makes no sense.but that's not the question here...
and don't worry there is no subject concerning the absence of usb... it will be on the next one.. and we will still come to the situation so common... "certainly I can't hear the difference, see even with mp3 at 320k.. but at least.. I know myself at topppp, I can go much further than the miserable 192k24bits!!!"
Well I would buy a Wiim product if there was usb output to pair w/ Schiit Ragnarok’s integrated DAC. But instead I’ll buy a Bluesound, which is overkill for Spotify Connect but it seems to be my best option.
hihi..
you are serious? ...
ahhhh.... And a comment like "your point makes no sense considering that spotify is only compressed.....not basicly qualitatif" is one of the absolute sort which really makes no sense.
(Schiit Ragnarok ..amplifier with analog input..but I can indeed have said a nonsense if this input is occupied not an fm tuner etc of course..mea culpa)Well I would buy a Wiim product if there was usb output to pair w/ Schiit Ragnarok’s integrated DAC. But instead I’ll buy a Bluesound, which is overkill for Spotify Connect but it seems to be my best option.
Okay well, Quboz Connect is coming and Spotify Connect is going high res soon right?hihi..
we've been waiting for years ( and indeed, if it arrives at the end of the year will be "cd quality", way deezer? flac 44/16?)...but your analog input is busy?Okay well, Quboz Connect is coming and Spotify Connect is going high res soon right?
The product I want to purchase: Wiim mini with an USB out so it is only being used as a streamer.we've been waiting for years ( and indeed, if it arrives at the end of the year will be "cd quality", way deezer? flac 44/16?)...but your analog input is busy?
This device is bus powered so unless the USB input on the DAC provides power its of no use in feeding an external DACHifime SPDIF Optical to USB converter, record DAT/minidisc to computer
The UR23 accepts SPDIF optical sources and transfer this to USB. Suitable to record DAT tapes, minidisc or other digital source to a computer.hifimediy.com
I may have misunderstood your point .. but there are cables allowing an integrated external power supply, right? (I personally use them for measurement purposes to treat my power supplies)This device is bus powered so unless the USB input on the DAC provides power its of no use in feeding an external DAC
