via specific cables, see diy...
I have kef x300a speakers with usb input. So it's a must for me if I want good quality music.from those who express it....
You just plug this directly into USB on a PC or a Raspberry Pi and it will get power from the host device. A powered hub is only necessary if there are too many other things being powered from the same host.The Hifime UR23 SPDIF Optical to USB converter has a hardwired USB A connector and a mini Toslink socket for an optical cable.
It draws its power via the USB connector.
I have never encountered an audio device that will supply power to a device connected to one of the audio device's USB input ports
I don't think you have this one as you are describing a SPDIF output device. This is for PC recording from SPDIF to USB.You just plug this directly into USB on a PC or a Raspberry Pi and it will get power from the host device. A powered hub is only necessary if there are too many other things being powered from the same host.
It’s actually a USB to Optical/3.5mm Aux converter. It incorporates a reasonable quality Sabre DAC capable of 24/96 IIRC. I have a couple somewhere or other.
Apologies you are correct.I don't think you have this one as you are describing a SPDIF output device. This is for PC recording from SPDIF to USB.
It can't be connected to a DAC according to the manufacturer so has limited use here.
Hifime SPDIF Optical to USB converter, record DAT/minidisc to computer
The UR23 accepts SPDIF optical sources and transfer this to USB. Suitable to record DAT tapes, minidisc or other digital source to a computer.hifimediy.com
"Please note that it can’t be connected directly to a USB device like a DAC, it must be connected to a USB host like a computer"
Is that not what the WiiM Ultra will provide?Any WiiM development on this topic?
To refresh… the interest is in a basic WiiM Pro with a bit perfect USB-c out.
Not really. A lot of people using external DACs with superior USB processing like Schiit Audio Unison USB just need a USB port out on a basic streamer. All the extras talked about on the Utra are never used. I do not need or want a screen. My Pro is at the back of a cabinet behind other equipment and I never see it.Is that not what the WiiM Ultra will provide?
Thanks for your lesson. Some of us bought the Pro a year ago. It fulfilled a role then. Things evolve, requirements change.One had to remember the Wiims are built to fit a certain budget in mind, adding in a decent USB controller adds costs. The port also doesn’t provide a huge amount of current so not suitable to DACs that need power from USB which users will have and want to use. So you would open up issues here. Best left to be added properly in a different model.
One has to ask why anyone would buy a Wiim if you wanted USB connection when there are devices that offer it. Its well known it only supports spdif and it’s not mentioned in any marketing. You buy hardware for what it does not what it might do.
Funny that - so true, yet my wife still sees it as just buying yet more hi fiThings evolve, requirements change.
So, what other streamers in the WiiM price range offer an USB-C output? Now if that option was available, no one would be questioning why WiiM didn’t offer it too.One had to remember the Wiims are built to fit a certain budget in mind, adding in a decent USB controller adds costs. The port also doesn’t provide a huge amount of current so not suitable to DACs that need power from USB which users will have and want to use. So you would open up issues here. Best left to be added properly in a different model.
