Digital output to external dac, e.g. dac/headphone amp.Hello. Will someone take 30 seconds to explain what a usb output would do? Thanks.
And just to expand on this a little:Digital output to external dac, e.g. dac/headphone amp.
Yes, I really want to get a fully integrated WiiM amp and bypass both the DAC and amp in favour of separate componentsI’m sure most users will pop their eyes if wiim can make rca input as pre out for more powerful amplifier.
Apologies if my attempt at humour wasn't obvious.What I really not understand is: Why buying an integrated amp with an integrated DAC and WiiMs streaming features when bypassing most of the features. With limited connectivity.
Why not a Pro, adding a DAC of choice and a real amp? With all the connectivity one wants to have.
It’s fine - there are a good few of us already in that clubSorry, I really thought your view on things was this way...a senior moment. Sorry again.
Yes, this is a feature many want, but on a device with an integrated DAC and speaker amp?To me, this is huge. Eliminates need to have DAC remote at the ready. And if DAC has multiple inputs, helps prevent potentially blown speakers.
Volume control (for those who want it) is available in the app. Not for me as that destroys bit perfect signal delivery to an external DAC.Sorry if it's been mentioned in this thread before (my eyes went blurry, really) but one very important reason is to control the volume of the USB DAC from the WIIM. Called a USB gadget, I believe. Using just the WIIM remote, one could control the possibly analog volume control in the DAC.
Some DACs support hardware volume control, which I think is what Left is referring to, which would allow the Wiim to control the DAC volume the same as using the volume control on the DAC itself. I don't know if this can be supported by the Wiim.Volume control (for those who want it) is available in the app. Not for me as that destroys bit perfect signal delivery to an external DAC.
No DAC worth listening too should offer a digital volume control. LowFi stuff sure.Some DACs support hardware volume control, which I think is what Left is referring to, which would allow the Wiim to control the DAC volume the same as using the volume control on the DAC itself. I don't know if this can be supported by the Wiim.
In any case my preference if available is to run the DAC at 100% and control volume at the analog stage.
That's not the question, it is whether the DAC volume control is available via USB control.No DAC worth listening too should offer a digital volume control. LowFi stuff sure.
Truly did not think my post would be contentious. After reading Hiphiman's post I understand why. The subject of this lengthy thread is "Feature Requests for WIIM Pro and Pro Plus." Not just for the WIIM amp. Many DACs have either analog volume controls attenuated via resistor ladders and similar, or digital volume controls that pad the bit lengths to at least 32 bits and fill the low bits with a dithered signal. These DACs are then fed directly to a power amp.Some contributors here question why someone might want to have USB out in a product which already has a DAC and amplifier. I can foresee a significant proportion of buyers subsequently wishing to upgrade from the WiiM Amp at some point with a better DAC and/or amp. As things stand it means (at best) having to repurpose the Amp and buying another streamer. At least having USB out means they can still use their Amp purchase as a streamer into the new kit, which I think is good thinking.
This implies you're waiting to use the wiim amp as a streamer to send its usb output to an external dac, and then back into the same wiim amp.Once this implement, I have various dac that will try. The dac analog out will be feed to analog input on wiim amp.
