steadyshot
- Joined
- Mar 14, 2023
- Messages
- 722
I knew the article cited inside the link you posted. If I'm non wrong, is interesting to note that the latter goes to different conclusions about what kind of filter to prefere, considering also that the frequency response is different from a filter to another.There is a nice explanation of reconstruction filters here:
Reconstruction Filters For Dummies • Music For The Masses
My personal experience and homework about reconstruction filters, with the hope this may be enlightening for some fellow audio enthusiast on their path to better understanding how our devices really workwww.audioreviews.org
I'm on the very comfortable position here as I do not hear differences between filtersI knew the article cited inside the link you posted. If I'm non wrong, is interesting to note that the latter goes to different conclusions about what kind of filter to prefere, considering also that the frequency response is different from a filter to another.
I tried to choice what kind of filter is more compliant to my preferences but, aside to the little sensation that there was something different, I didn't able to say that one was better...
Me too I'm thinking is conseguence of some sort of bias but in fast change from one to another filter, relatively to 44.1, the sensation of something different, in snare shot tails or acoustic guitar strumming and even female voices, is present, subtle and quite impossible to choice a winner...I'm on the very comfortable position here as I do not hear differences between filters
Finally someone admits it. We are two with me. At least.I'm on the very comfortable position here as I do not hear differences between filters
That is why, in the absence of a clear sign, I defaulted to the most mathematically correct solution - "Linear fast rolloff". See http://archimago.blogspot.com/2022/06/review-smsl-do100-dac-dual-ess.html and the aforementioned https://www.audioreviews.org/reconstruction_filters_dummies/Three! Checked all my available filters during the afternoon. Not even a feeling although I tried quite hard to find one
If find the coffee filter is the most beneficial
Invented by Melitta Bentz....of course a GermanIf find the coffee filter is the most beneficial
You should admit that the "awareness" of one solution that is formally better than another, recognizable or not at a glance, takes to more peaceful mood, better if with a good coffee taste in mouth...If find the coffee filter is the most beneficial
Break it to continuous posts?There is a limit of 10 attachments included... How can I write my review without graphs?
I did just like you did choosing “Fast Linear”. By the way it’s the default filter of my SMSL 500 MKIII.That is why, in the absence of a clear sign, I defaulted to the most mathematically correct solution - "Linear fast rolloff". See http://archimago.blogspot.com/2022/06/review-smsl-do100-dac-dual-ess.html and the aforementioned https://www.audioreviews.org/reconstruction_filters_dummies/
The limit of 10 has been extended to 20 so that should be sufficient. Please try again.There is a limit of 10 attachments included... How can I write my review without graphs?
Thank you.The limit of 10 has been extended to 20 so that should be sufficient. Please try again.
