Audio dropouts with pro plus
Bozzz
Nov 5, 2023
36
Hi community. I’m having a bit of an issue I hope I can get some help with. Every so often the audio will cut out when I’m streaming Qobuz through the WiiM app. The song I’m playing doesn’t pause just the sound. I’m using evergreen rca out cables to my Willsenton r8 if that helps. Also I have the plus connected directly with Ethernet. Any help would be appreciated. Thanks.
I'm having the same problems with Spotify both through Spotify Connect, and through Bluetooth (both using line out to my receiver). It does seem worse through Bluetooth. It's driving me nuts! I submitted a support ticket 4 days ago, and haven't heard anything.
It seems that sometimes the network options in the wiim app can affect spotify (maybe others too).
Try changing the ipv6 and preferred dns server settings.
I've toggled the ipv6 and DNS Server settings to no avail. Now I'm even having the issue using my HD radio that is connected to the Wiim optical in.
