Pro plus not seeing as roon ready
ElTitoPricus
Oct 21, 2023
8
I just bought the wiim pro plus and it only appears as airplay.
Is this one the latest firmware, it's driving me crazy.
Can someone help me, please?
In the WiiM home app, under music services/manage, have you toggled on Roon Ready? And then, on the browse page, what happens when you then select Roon Ready?
I just tried one last time before going to the shop, and it worked, as soon as he was On, the update started and now roon ready appears.
I don't know why, but hey, it works. IS this the latest firmware?
Thanks
  • Like
Reactions: SWM
Thanks
In the device info screen it shows the firmware build date - check that.
For example, your first screenshot shows 20230615
Definitely don't believe the check for update screen ;)
I'm still convinced the code behind that says sleep 1, print up to date...
